Synthetic Monitoring
application authenication with SAML
naujla85
Newcomer_
i was using synthetic monitoring for a SaaS application that can only be used in a private endpoint. I had the username and password saved in the vault.
The active directory has integrated SSO for the SaaS application using SAML. I have option to manually enter the service username and password for the application but everytime I try to click on it fails.
I was thinking of trying managed identify as both the application are under Azure AD or shall i go for certificates.
HannahM
Dynatrace Guru
Dynatrace Guru
Have you added the credentials to the HTTP Authentication section of the Navigate event? https://docs.dynatrace.com/docs/platform-modules/digital-experience/synthetic-monitoring/general-inf...
