If it were not a random code, a voicemail on a dedicated number could authenticate. Since it is a random code, that no longer will work.
I have been looking into OKTA, but from the HTTP monitor perspetive, and no 2FA. 2FA is always particularly difficult to script...
If we can bypass 2FA for the dummy user, will Synthetic able to login into Okta and reach the app?
I have not tried hard to get this working, as it takes a lot of actions, which has a great impact on DEM consumption. But I would say so to your question.
Is there an API we could use to get the verification code from? If you have the code that generates the 'random' code, could we add that to a javaScript event to generate it through the script? Can the code only be sent to sms, could you use an a webmail account that you could check as part of the monitor?
Alternatively, if you are not specifically testing that 2FA works can you add something into your application that checks for our User Agent string and if it's included skips the 2FA.
