on
12 Oct 2026
10:13 AM
- edited on
12 Oct 2026
12:32 PM
This article helps you troubleshoot the Dynatrace AWS S3 log forwarder that sends logs from Amazon S3 to Dynatrace. The forwarder is a serverless deployment (S3 → SQS → Lambda) placed in Customer AWS account.
There are two versions of the forwarder, and each has its own troubleshooting guide. This article helps you pick the right one.
dynatrace-aws-platform-monitoring-s3-log-forwarder - intended for environments using the new Dynatrace AWS Cloud Platform Monitoring.
dynatrace-aws-s3-log-forwarder - intended for environments using Dynatrace Classic for AWS cloud monitoring.
Your S3 log forwarder deployment fails, or logs from S3 don't show up in Dynatrace. You may see one of these symptoms:
Identify which forwarder you deployed. The simplest way is to check the description of the main forwarder CloudFormation stack in AWS. The description also contains a link to the correct GitHub repository.
Open the guide for your forwarder and go to the section that matches your symptom.
AWS Platform Monitoring forwarder: Troubleshooting guide
Classic forwarder: Troubleshooting guide
Both guides cover:
If this article didn't help, create a chat or open a support case.
