Troubleshooting
xu_guo
Dynatrace Organizer
Dynatrace Organizer
HTTP Monitor
  • If the HTTP monitor fails on the AG what are the troubleshooting steps? Verify if the request works on the AG itself and request for the logs of the output of curl command.
    • No proxy:
      curl –vvv –i –k –L -H "User-Agent: DynatraceSynthetic/1.179" url
    • Proxy:
      curl –vvv –i –k –L -H "User-Agent: DynatraceSynthetic/1.179" –x http(s)://proxyhost:proxyport –proxy-user username:password url
    • Auth: Adjust URL to this: https://username:password@test.com
  • If an HTTP Monitor Times out. Verify that the request is not taking longer than 10 seconds (default). Run the following from ActiveGate (If required add proxy configs from above):
    • time curl –vvv –i –k –L -H "User-Agent: DynatraceSynthetic/1.179 url
Browser Monitor (ClickPath)
  • If the Browser Monitor is having connection issues, verify if the request works on the AG itself and request for the logs of the output of curl command
    • No proxy:
      curl –vvv –i –k –L -H "User-Agent: Mozilla/5.0 (iPhone; CPU iPhone OS 8_0 like Mac OS X) AppleWebKit/600.1.3 (KHTML, like Gecko) Version/8.0 Mobile/12A4345d Safari/600.1.4 RuxitSynthetic/1.0" url
    • Proxy:
      curl –vvv –i –k –L -H "User-Agent: Mozilla/5.0 (iPhone; CPU iPhone OS 8_0 like Mac OS X) AppleWebKit/600.1.3 (KHTML, like Gecko) Version/8.0 Mobile/12A4345d Safari/600.1.4 RuxitSynthetic/1.0" –x http(s)://proxyhost:proxyport –proxy-user username:password url
  • Test the Application Manually with Chromium configurations enabled.
    • Without GUI on private synthetic location
cd ~ export DISPLAY=:99; /opt/dynatrace/synthetic/browser --headless --screenshot https://<site-of-interest>
A full command line example with our extension loaded would look something like
cd ~ export DISPLAY=:99;  /opt/dynatrace/synthetic/browser --user-data-dir=/var/tmp/dynatrace/synthetic/cache/vuc_work_diagnostics --disk-cache-dir=/var/tmp/dynatrace/synthetic/cache/vuc_work_diagnostics_cache --disk-cache-size=104857600 --disable-popup-blocking --ssl-version-min=tls1 --test-type --ignore-certificate-errors --no-default-browser-check --no-first-run --disable-translate --disable-web-security --disable-background-networking --disable-plugins-discovery --dns-prefetch-disable --noerrdialogs --disable-default-apps --disable-desktop-notifications --disable-crl-sets --allow-outdated-plugins --always-authorize-plugins --disable-web-resources --silent-debugger-extension-api --disable-internal-flash --disable-bundled-ppapi-flash --disable-appcontainer --user-agent="Mozilla/5.0 (X11; Ubuntu; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/78.0.3904.87 Safari/537.36 RuxitSynthetic/1.0 v87769033 t7840928177123288742" --load-extension=/opt/dynatrace/synthetic/vucontroller/playback/playbackengine,/opt/dynatrace/synthetic/vucontroller/playback/websocketextension --disable-extensions-except=/opt/dynatrace/synthetic/vucontroller/playback/playbackengine,/opt/dynatrace/synthetic/vucontroller/playback/websocketextension --window-size=1024,768 --window-position=100,100 --proxy-server="http=<proxy-host>:<proxy-port>;https=<proxy-host>:<proxy-port>;" --proxy-bypass-list="localhost;<list-of-coma-separated-hosts>;" --headless --screenshot http(s)://<site-of-interest>
With GUI on private synthetic location default path: /usr/bin/chromium-browser (double click on the chromium browser to start up and use just like the chrome browser)
On Windows with redirects following and printing raw response:
Invoke-WebRequest -MaximumRedirection 10 -Uri "<url you are testing>" | Select-Object -Expand RawContent
More commands can be found here: Firewall Constraints and allowlisting for Synthetic Monitoring.
Version history
Last update:
‎20 Feb 2024 08:46 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Great troubleshooting writeup @xu_guo
