Troubleshooting
michael_altenhu
Dynatrace Promoter
Dynatrace Promoter
Summary
In specific situations, Davis CoPilot Chat responses might be blocked by network security solutions (e.g., McAfee Web Gateway).
Problem
Davis CoPilot responds with the following error message :
Something's gone wrong, and we couldn't process Davis CoPilot's response. Please wait a moment, then try again. If the issue persists, please contact support.
It might generate an incomplete answer or not work at all.
If this message appears persistently, it is a hint that a network security solution accidentally filters Davis CoPilot chat's response. McAfee Web Gateway is known to be especially affected.
Note that the features Query with AI and Explain query with AI are not affected.
What's next
As this problem occurs in your local network, raising the issue with the security solution vendor is recommended.
Version history
Last update:
‎15 Apr 2026 09:28 AM
Updated by:
Comments
JR79
Guide
Does someone have a solution, a workaround or a reference of an issue opened at McAfee for this please?
