Troubleshooting
TeoMoldovanu
Dynatrace Helper
Dynatrace Helper
A vulnerability might be identified incorrectly. Possible reasons for false positives include:
  • The extracted information from the software component isn't correct and a wrong library was identified (for example, due to wrong information in the pom.xml file).
  • The identified version of the library has a version string (or a well-known identifier) that was incorrectly parsed or compared. If you see any false positive results, please open a support ticket to help us improve Application Security monitoring.
  • A vulnerability in a certain library is only exploitable if used in combination with a particular runtime version, but the application with the library is run using a different runtime version. You can mute the vulnerability for the process groups where a different runtime version is used.
  • The application uses string caches which might lead to false-positive attacks and code-level vulnerabilities.
For more information on how to identify false positives, query the relevant process for information via API, and mute false positives, see Reported vulnerability is considered as a false positive.
Version history
Last update:
‎14 Mar 2024 11:55 AM
Updated by:
