on
28 Nov 2023
06:10 AM
- edited on
21 Jan 2026
10:41 AM
IzabelaRokita
Summary: The post explains why Slack channels may not appear in Dynatrace integration settings and provides steps to resolve the issue. Common causes include permission settings and Slack API configurations.
By default, Slack apps can only send messages to public channels in the workspace they're a part of. If you can't find a specific channel, it's most likely a private channel.
To send messages to a private channel, you need to add your app to the channel manually.
