 HannahM
			HannahM
		17 Aug 2023 05:12 PM - edited 16 Jun 2025 03:44 PM
By default, Browser Monitors are executed in a Chrome Browser that ignores certificate errors. In some scenarios, you may wish for your Browser Monitor to fail if there is a certificate error.
These steps will work for all location types - Public, Private, and Cluster.
Go to Synthetic in the Dynatrace menu.
Select Create a synthetic monitor in the top right > Create a browser monitor.
On the Configure a browser monitor page, type in the URL you want to monitor and either use the default Name or provide your own.
            "ignore-certificate-errors": false
Select Next at the bottom of the page to view the monitor summary.
On the Summary page, you can review and change your configuration (Change URL or name; Change configuration).
At the bottom of the page, select Create browser monitor.
Select the browser monitor you want to configure.
Select Edit from the quick links to go to monitor settings. Alternatively, you can go to the Synthetic monitors page, select the checkbox next to the monitor you want to edit, and select Edit at the bottom of the page.
If you would like to be warned in advance of the certificate's expiry, you can use the HTTP Monitor SSL Certificate expiry option.
https://www.dynatrace.com/support/help/platform-modules/digital-experience/synthetic-monitoring/http...
If you still need assistance, open a chat or support ticket and provide a link to the affected monitor and explain what your are trying to do and what you have already tried.
You can find further troubleshooting tips for Synthetic in the Synthetic Troubleshooting Map
 AntonioSousa
			AntonioSousa
		I confess I'm a little bit confused here, and not what I was expecting: by default, a Chrome Browser does not ignore cert errors, but indeed tries that the user not proceed to a site with an invalid cert.
This implies that sites with a self-signed, invalid CA or whatever invalid cert may be out there, do not give an error by default in browser monitors?
 AntonioSousa
			AntonioSousa
		Thanks for the clarification. If asked before, I would certainly not have said it worked this way 😁 But I do understand why it's done this way...
Hello everyone,
I'm in need for such feature (i.e. I want the synthetic to fail if there are any certificate issues).
I've added the suggested flag but the synthetic is still not failing even tough there are certificate issues...
Anyone had success with this setup?
Thanks 🙂
@lsantos, thanks for letting us know. Did you resolve this issue? Changing the flag works for me. If this behavior is still seen for your monitor, can you create a support ticket for us to investigate? Thanks
