Troubleshooting
HannahM
Dynatrace Guru
Dynatrace Guru
Summary
By default, Dynatrace browser monitors run in a Chrome instance that ignores certificate errors. In some cases—such as testing secure environments—you may want your browser monitor to fail when an invalid or expired certificate is detected.
This guide explains how to create or update a browser monitor so that it enforces certificate validation across all location types (public, private, and cluster).
Resolution
To ensure your browser monitor fails when certificate issues occur, set the Chromium startup flag ignore-certificate-errors to false / disabled.
(Latest Dynatrace) How to create a Browser Monitor that doesn't ignore certificate errors
  1. Go to Synthetic in latest Dynatrace.
  2. Select  New monitor > Browser.
  3. Configure the monitor, as required. See docs for steps.
  4. On the Advanced setup tab, expand Chromium Startup Flags.
  5. Set Ignore certificate errors to Disabled.
  6. Select Continue.
  7. See the summary of all the steps. If everything's OK, and no more adjustments are needed, Save the newly configured monitor.
(Latest Dynatrace) Update a Browser Monitor to not ignore certificate errors
  2. Select the browser monitor you want to configure.
  3. Select Edit.
  4. Select the Advanced Setup tab.
  5. Expand Chromium Startup Flags.
  6. Set Ignore certificate errors to Disabled.
  7. Select Save
(Classic) How to create a Browser Monitor that does not ignore certificate errors
  1. Go to Synthetic in the Dynatrace Classic menu, or open the Synthetic Classic app in latest Dynatrace.
  2. Select Create a synthetic monitor in the top right > Create a browser monitor.
  3. On the Configure a browser monitor page, type in the URL you want to monitor and either use the default Name or provide your own.
  4. Select Script Mode
  5. Add the following to the configuration section under chromiumStartupFlags
                "ignore-certificate-errors": false​
  6. Add any further steps required
  7. Choose Next to continue configuration—select monitor locations and frequency. See Configure browser monitors for details.
  8. Select Next at the bottom of the page to view the monitor summary.
  9. On the Summary page, you can review and change your configuration (Change URL or name; Change configuration).
  10. At the bottom of the page, select Create browser monitor.
(Classic) Update a Browser Monitor to not ignore certificate errors
  1. Go to Synthetic in the Dynatrace Classic menu.
  3. Select Edit from the quick links to go to monitor settings. Alternatively, you can go to the Synthetic monitors page, select the checkbox next to the monitor you want to edit, and select Edit at the bottom of the page.
  4. Select Recorded Clickpath , if it's a Browser Clickpath monitor, or Monitor Script
  5. Select Script Mode
  6. Add the following to the configuration section under chromiumStartupFlags
  7.  Select Save Changes
What's Next
Get advanced warning of a certificate expiring
If you would like to be warned in advance of the certificate's expiry, you can use the HTTP Monitor SSL Certificate expiry option.
https://www.dynatrace.com/support/help/platform-modules/digital-experience/synthetic-monitoring/http...
Further troubleshooting
If you still need assistance, open a chat or support ticket and provide a link to the affected monitor and explain what your are trying to do and what you have already tried.
Related reading
📖  Synthetic Troubleshooting Map
📖  Synthetic Browser Monitor Error Codes
📖  Create and configure a browser monitor
📖  (Classic) Browser monitor script mode
Version history
Last update:
‎21 Aug 2026 03:16 PM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thank you for Sharing this @HannahM
AntonioSousa
@HannahM,
I confess I'm a little bit confused here, and not what I was expecting: by default, a Chrome Browser does not ignore cert errors, but indeed tries that the user not proceed to a site with an invalid cert.
This implies that sites with a self-signed, invalid CA or whatever invalid cert may be out there, do not give an error by default in browser monitors?
HannahM
Dynatrace Guru
Dynatrace Guru
For Browser monitors, we start the Browser with the
--ignore-certificate-errors
parameter. This does indeed ignore certificate errors.
AntonioSousa
@HannahM,
Thanks for the clarification. If asked before, I would certainly not have said it worked this way 😁 But I do understand why it's done this way...
lsantos
Observer
Hello everyone,
I'm in need for such feature (i.e. I want the synthetic to fail if there are any certificate issues).
I've added the suggested flag but the synthetic is still not failing even tough there are certificate issues...
Anyone had success with this setup?
Thanks 🙂
HannahM
Dynatrace Guru
Dynatrace Guru
@lsantos, thanks for letting us know. Did you resolve this issue? Changing the flag works for me. If this behavior is still seen for your monitor, can you create a support ticket for us to investigate? Thanks
AlanZ
Helper
We would like this to be the default for all browser monitors (new and existing). Is there a setting which would modify the default behavior so certificates are always validated for all our environment browser monitors unless otherwise specified ?
HannahM
Dynatrace Guru
Dynatrace Guru
Hi Alan, unfortunately not, but it's a great idea. I recommend you add it here
Julius_Loman
DynaMight Legend
DynaMight Legend
I disagree with this behaviour. Certificate validity must be checked by default, with the option of supplying your own list of CA certificates.
Disabling certificate validation must be an opt-in, not the other way around. When users create synthetic tests, they expect the test to behave exactly as it does in their real browser.
This is especially critical since the current option to turn off ignoring the errors is hidden and not exposed to the user in contrast to HTTP monitors.
