Mareeswaran
Dynatrace Helper
Dynatrace Helper
Steps to follow to perform the mouseover event on browser click path synthetic monitor
  1. Go to the relevant page on Chrome browser
  2. Right click on the element which you want to interact with on the page-> Inspect the element which will open the developer tools
  3. Right click on the element on the Web developer tools - > Copy - > Copy JS path
  4. Paste the JS path on the below element value and add this JavaScript code into the JavaScript Event of your Browser click path monitorimage3.png
    function triggerevent(element)
    var evt = document.createEvent("MouseEvent");
    evt.initMouseEvent("mouseover",true, true);
    element.dispatchEvent(evt);
    var element = document.querySelector('button[id="testid"]'); //Replace with the element which you want to perform the mouseover action.
    triggerevent(element);
Version history
Last update:
‎12 Apr 2023 10:20 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
@Mareeswaran Thank you for sharing this
