Troubleshooting
akram_elkhangy
Dynatrace Guide
Dynatrace Guide
In case of un-installing Dynatrace operator for classicFullStack and applicationMonitoring without CSI driver on Openshift.
You may face the below/similar error due to inability to access the file system.
Cleaning up /opt/dynatrace/oneagent/agent. Part of configuration preserved in /var/lib/dynatrace/oneagent ERROR: ld.so: object '/opt/dynatrace/oneagent/agent/bin/current/linux-x86-64/liboneagentproc.so' from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
In such scenario you can perform one of the below steps:
1- ssh access to the worker node and run the uninstall script
2- login under debug container, elevate the permissions and then run the script
"oc debug node/<node-name>"
"chroot /host"
"uninstall.sh "
Documentation page for un-installing the operator
Version history
Last update:
‎30 May 2023 12:43 PM
Updated by:
Comments
ChadTurner
Legend
Thank you for sharing this @akram_elkhangy
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
