 anton_konikov
			anton_konikov
		on 27 Sep 2024 08:48 AM
To illustrate, we’ll employ Podman as our container runtime and set up Jenkins within it. For that, you could use the following command:
podman run --name jenkins -d -e OTEL_LOGS_EXPORTER="otlp" -p 8080:8080 jenkins/jenkins:lts
Once the container is up and running in your favorite browser, let's navigate to http://localhost:8080/ and, follow the shown instruction and login into Jenkins.
As the second step, from the main Jenkins view Dashboard, click on Manage Jenkins and then on Plugins:
On this step, let's install OpenTelemetry plugin. Select Available pugins and type OpenTelemetry in the search bar. Select the plugin and depending on the Jenkins version, press Install button or Install without restart.
After the installation is sucesfully finished, scroll down and select Restart Jenkins when installation is complete and no jobs are running:
Now let's go to Dynatrace UI and generate an API token
From Manage Jenkins view, navigate to System configuration:
Scroll to the OpenTelemetry section and in the OTLP endpoint sectrion specify your SaaS OTLP API endpoint, e.g. https://{your-environment-id}.live.dynatrace.com/api/v2/otlp, in the Authentication section, select Header Authetication and type in the filed Header Name: Authorization:
For the Header Value, create a new secret tocken by seceting Add > Jenkins. You’ll need to create a secret text with the following fields:
Authorization: Api-Token dt.....Dynatrace API ingest token. Then scroll down to Advanced configuration and expand it. In the Configuration properties filed paste: otel.exporter.otlp.protocol=http/protobuf, as gRPC is not yet supported:
Additionally you can configure visualisation backend to show the link between build and trace in Dynatrace:
Please make sure that OTLP Endpoint set up earlier is accesible from Jenkins location. Let's create the first test pipeline and verify the monitoring data can be observed.
Click on New Item and create the Pipeline job:
Then scroll down to the Pipeline configuration and select the Github+Maven sample or paste the bellow snippet:
pipeline {
    agent any
    tools {
        // Install the Maven version configured as "M3" and add it to the path.
        maven "M3"
    stages {
        stage('Build') {
            steps {
                // Get some code from a GitHub repository
                git 'https://github.com/jglick/simple-maven-project-with-tests.git'
                // Run Maven on a Unix agent.
                sh "mvn -Dmaven.test.failure.ignore=true clean package"
                // To run Maven on a Windows agent, use
                // bat "mvn -Dmaven.test.failure.ignore=true clean package"
            post {
                // If Maven was able to run the tests, even if some of the test
                // failed, record the test results and archive the jar file.
                success {
                    junit '**/target/surefire-reports/TEST-*.xml'
                    archiveArtifacts 'target/*.jar'
Note: the prerequisite is to install Maven, which requires defining Maven instance in the Mange Jenkins > Tools:
After finishing the configuration of the pipeline job you can click on the Build Now button which then trigger execution of the pipeline:
Additionally, we encourage you to watch this demo session Dynatrace Tips & Tricks #18 - Jenkins Pipeline Analytics with OpenTelemetry.
Hi @anton_konikov ,
Can we use this solution on Managed environment with OTLP traces v1 api?
Thanks in advance.
Best reagrads,
Mizső
For those who get traces but no logs, we needed to add the following parameters to get the build logs.
otel.instrumentation.jenkins.remote.span.enabled=true
otel.instrumentation.jenkins.agent.enabled=true
otel.logs.exporter=otlp
otel.logs.mirror_to_disk=true
 anton_konikov
			anton_konikov
		Hi @hnimawat,
Embedded OpenTelemetry knows the trace ID and substitutes it into the URL to your Managed. However, the trace was not exported to Dynatrace server.
This can happen e.g. when OpenTelemetry doesn't trust your certificate of the endpoint, but the real issue you could see in the Jenkins logs.
The preferable solution would be to add this certificate for Jenkins/OTLP or alternatively, you can use a Dynatrace OTLP collector as the middle point of the architecture to aggregate all OTEL data. Then add the certificate from your Managed to this collector or add an option to skip TLS cert verify (as Dynatrace we recommend avoiding using this option).
