darynakovyrina
Dynatrace Mentor
Dynatrace Mentor
Dynatrace version 1.275+
When the invalid credentials disablement mechanism is triggered, Dynatrace generates an event to alert you that the credentials used for VMware monitoring are invalid. The event remains active for up to 6 hours and will automatically close after this period.
The event may close earlier if the affected credentials are corrected or completely removed from the settings. Alternatively, you can manually close the problem if you consider it resolved or irrelevant.
Version history
Last update:
‎28 Nov 2023 10:30 AM
Updated by:
Comments
radek_jasinski
Thank you!
