Troubleshooting
TeoMoldovanu
Dynatrace Helper
Dynatrace Helper
OneAgent in Infrastructure Monitoring mode automatically injects into processes to be able to monitor backing services written in Java and runtime metrics for supported languages. If the auto-injection is disabled for individual hosts, related vulnerabilities can't be assessed.
To enable auto-injection in Infrastructure Monitoring mode, you need to enable runtime metrics.
To enable runtime metrics
  1. From the Dynatrace menu, select Settings > Monitoring > Monitored technologies.
  2. In the list of supported technologies, search for the Java/.NET/Node.js/Golang/PHP runtime metrics + WebServer metrics in Infrastructure Mode entry.
  3. Select the pencil icon to edit it and then enable it.
  4. Restart all processes on your infrastructure-monitored hosts.
For details, see Process injection in Infrastructure Monitoring mode.
Version history
Last update:
‎24 Nov 2023 07:30 AM
Updated by:
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
