Troubleshooting
karolinaboba
Dynatrace Advisor
Dynatrace Advisor
If you bookmarked the Dynatrace Managed page or saved a shortlink (not the entire URL path) to the Dynatrace documentation before the separation of SaaS and Managed content, you might be getting this error now:
Basically, it means that the shortlink needs updating. You can fix the link on your own by simply changing one word in the URL from docs to managed:
to:
Note that if the topic applies to both - SaaS and Managed - the same page will be accessible in two places with two different URLs. See page example that appears in both SaaS and Managed doc:
Version history
Last update:
‎29 Apr 2024 04:09 PM
Updated by:
