Troubleshooting
ilya_gutin
Dynatrace Guide
Dynatrace Guide
If you stopped receiving Slack problem notifications from Dynatrace, check your Slack Webhook.
The Slack Incoming Webhook URL (created by the Slack admin) is specific to a single user and a single channel. If you're relying on a webhook tied to a deactivated account or channel, the webhook URL is invalid, breaking the integration, which means you no longer receive messages in Slack.
If so, ask your Slack admin to generate a new webhook URL using a valid account and channel. Once a new URL is generated, update the webhook URL in Dynatrace and test the connection. If you need a reminder on how to configure notifications, see Send Dynatrace notifications to Slack.
Version history
Last update:
‎20 Dec 2023 12:30 PM
Updated by:
Comments
radek_jasinski
Good! Thank you
