Troubleshooting
ShahbazKhan
Dynatrace Guide
Dynatrace Guide
Summary
This article explains how to troubleshoot and fix the issue where the Dynatrace Synthetic Recorder extension is blocked in Chrome or Microsoft Edge when using Incognito or InPrivate mode.
This issue is typically caused by browser policies such as ExtensionInstallForcelist, which prevent the extension from running in Incognito mode.
Problem
When attempting to record a Synthetic Browser monitor (new or existing), the recorder opens an Incognito or InPrivate window, but the extension fails to load.
You may see an error such as:
  • “This page has been blocked by Chrome”
  • ERR_BLOCKED_BY_CLIENT
As a result:
  • Recording does not start
  • The page remains blocked indefinitely
Text from Image:
pbnfcaobikkbealhienfilklacghhgoi is blocked
Cause
This behavior occurs when:
  • The Dynatrace Synthetic Recorder extension is force-installed via policy
  • The extension ID is configured in:
This restriction specifically impacts:
  • Incognito (Chrome)
  • InPrivate (Edge)
Option 1 – Update browser policy (recommended)
If using ExtensionInstallForcelist, ensure developer tools are allowed.
Set the following policy:
HKLM\Software\Policies\Google\Chrome\
DeveloperToolsAvailability = 1
This enables the extension to function correctly in Incognito mode.
Option 2 – Disable Incognito for recording (workaround)
If policies cannot be changed, you can avoid Incognito mode entirely.
Key points:
  • The Synthetic Recorder uses Incognito for a clean session
  • Disabling it allows recording without policy restrictions
  • This only affects local recording, not monitor execution
When to Use This Fix
Apply this solution if:
  • Your organization enforces browser extensions via Group Policy
  • Incognito mode is restricted or controlled
  • The Synthetic Recorder extension appears blocked in Chrome or Edge
Best Practices
  • ✅ Validate browser policies before installing the extension
  • ✅ Avoid forcing extensions unless necessary
  • ✅ Provide exceptions for DeveloperToolsAvailability where required
  • ✅ Test recording both with and without Incognito
What’s Next
If the issue persists:
  1. Confirm browser policy settings (Chrome/Edge)
  2. Verify extension installation method
  3. Test recording without Incognito
  4. Collect error screenshots and browser logs
Then open a Dynatrace support chat with:
  • Policy configuration details
  • Extension setup method
  • Exact error message
Related reading
📖  How to record or playback a Browser Monitor without Incognito mode
📖  DeveloperToolsAvailability
📖  ExtensionInstallForcelist
Version history
Last update:
‎12 Jun 2026 09:19 AM
Updated by:
Comments
bill_smith
Dynatrace Participant
What causes the extension to be added to this registry list?  Some anti-malware software?
ShahbazKhan
Dynatrace Guide
Dynatrace Guide
It’s mostly via Customer’s Group Policy to ensure uniformity across all devices
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
