Troubleshooting
noel_david
Dynatrace Advisor
Dynatrace Advisor
Summary
This article provides a practical troubleshooting guide for resolving common issues when ingesting Syslog via Dynatrace ActiveGate.
Setup
Deploy Environment ActiveGate
Installation steps
Enable syslog ingestion on ActiveGate
Edit the /var/lib/dynatrace/remotepluginmodule/agent/conf/extensionsuser.conf file and add the following flag:
syslogenabled=true
For more details, please check the documentation
Syslog ingestion with ActiveGate — Dynatrace Docs
Edit the syslog receiver configuration.
Syslog ingestion configuration in Dynatrace uses the following YAML setup
receivers:
syslog/udp:
udp:
listen_address: "0.0.0.0:514"
add_attributes: true
protocol: rfc5424
operators:
- type: syslog_parser
protocol: rfc5424
syslog/tcp:
tcp:
listen_address: "0.0.0.0:601"
protocol: rfc5424
operators:
protocol: rfc5424
Troubleshooting
Check the protocol used in the YAML file configuration
By default, the ingested syslog must be in the format defined by RFC3164 and RFC5424.
RFC 3164 log example
<134>Jul 3 15:15:06 DOE-APL-WAF-01.doe.local ASM:CEF:0
F5 ASM 17.1.2 Successful Request
dvchost=DOE-APL-WAF-01.doe.local dvc=10.20.20.3 cs1=/Common/UNIFIEDPLATFORM_PROD_SEC_POL.app/UNIFIEDPLATFORM_PROD_SEC_POL cs1Label=policy_name .
Structure of an RFC 3164 Message
<PRI>TIMESTAMP HOSTNAME TAG: MESSAGE
  • Priority value combining facility and severity (e.g., <134>)
  • TIMESTAMP: Format MMM DD HH:MM:SS (e.g., Jul 3 15:15:06)
  • HOSTNAME: Originating device or system (e.g., DOE-APL-WAF-01.doe.local)
  • TAG: Application or process name (e.g., ASM:CEF:0)
  • MESSAGE: The actual log content
RFC5424 log example
<34>1 2025-07-02T11:20:20.003Z mymachine.example.com myapp 12345 ID47 [exampleSDID@32473 iut="3" eventSource="Application" eventID="1011"] BOMAn application event log entry...
Structure of an RFC 5424 Message
<PRI>VERSION TIMESTAMP HOSTNAME APP-NAME PROCID MSGID [STRUCTURED-DATA] MESSAGE
  • Priority value (facility + severity)
  • VERSION: Syslog version (always 1)
  • TIMESTAMP: ISO 8601 format (e.g., 2025-07-02T11:20:20.003Z)
  • HOSTNAME: Originating system (e.g., mymachine.example.com)
  • APP-NAME: Application name (e.g., myapp)
  • PROCID: Process ID (e.g., 12345)
  • MSGID: Message ID (e.g., ID47)
  • STRUCTURED-DATA: Optional metadata in key-value format
  • MESSAGE: Free-form text message
If the logs are meeting this standard, ingestion can still be done with the help of Dynatrace OpenPipeline.
Troubleshooting Syslog Ingestion When Standards Aren’t Strictly Followed.
Check the Otel Collector logs
If ActiveGate receives the log records, you should see entries as in the example below:
[otelSyslog][otelSyslog][37448][err]LogRecord #3
[otelSyslog][oteiSyslog][37448][err]ObservedTimestamp: 2024-05-06 @9:52:10.6748723 +8000 UTC
[otelSyslog][otelSyslog][37448][err]Timestamp: 2624-05-@6 11:52:16 +90e0 UTC
[otelSyslog][otelsyslog][37448][err]SeverityText: info
[otelSyslog][otelSyslog][37443][err]SeverityNumber: Info(9)
[otelSyslog][otelSyslog][37448][err]Body: Str(<30>May 6 11:52:10 SOME-HOST systemd[1]: Finished Load Kernel Module fuse.)
[otelSyslog][otelSyslog][37448][err]Attributes:
[otelSyslog][otelSyslog][37448][err] -> priority: Int(3)
[otelSyslog][otelSyslog][37448][err] -> facility: Int(3)
[otelSyslog][otelSyslog][37448][err] -> appname: Str(systemd)
[otelSyslog][otelSyslog][37448][err] -> proc_id: Str(1)
[otelSyslog][otelSyslog][37443][err] -> log: Map({“source": “syslog"})
[otelSyslog][otelSyslog][37443][err] -> hostname: Str(SOME-HOST)
[otelSyslog][otelSyslog][37443][err] -> message: Str(Finished Load Kernel Module fuse.)
[otelSyslog][otelSyslog][37448][err]Trace ID:
[otelSyslog][otelSyslog][37448][err]Span ID:
[otelSyslog][otelSyslog][37443][err]Flags: 0
Verify the Otel collector process is listening on the expected  port
 This can be verified with the below command so  that the otel collector process is listening on the expected  port, and no other application uses the port
sudo netstat -tulnp | grep otel
This command lists all TCP/UDP listening ports and filters for processes related to OTel. You’ll see output like:
udp        0      0 0.0.0.0:514           0.0.0.0:*       1234/otelcol
tcp        0      0 0.0.0.0:4317          0.0.0.0:*       1234/otelcol
  • 514 might be used for syslog ingestion.
  • 4317 is the default port for OTLP over gRPC.
  • 1234/otelcol indicates the process ID and name.
Analyze logs and traffic using TCP dump
Use the below command to verify that the logs are coming
sudo tcpdump -A -i any port <port>
A sample output might look like:
15:15:06.123456 IP 10.20.20.3.514 > 10.20.20.4.514: SYSLOG
<134>Jul 3 15:15:06 DOE-APL-WAF-01.doe.local ASM:CEF:0 F5 ASM 17.1.2 Successful Request dvchost=DOE-APL-WAF-01.doe.local dvc=10.20.20.3 cs1=/...
This shows:
  • Timestamp
  • Source and destination IPs and ports
  • Protocol (e.g., SYSLOG)
  • Message content (e.g., CEF-formatted log from an F5 device)
Validate SELInux and firewall
Review the firewall settings and ensure that incoming traffic is allowed on the specified port.
The below is an example command that can be used to verify that
sudo firewall-cmd --zone=public --query-port=514/udp
If the  output is:
yes
This confirmed that UDP traffic on port 514 was allowed
The SELinux configuration was checked using be below example command:
sudo semanage port -l | grep http_port | grep 514
If the result is as below, then it's configured correctly :
http_port_t udp 514
As an additional test, configure syslog to listen on a higher port, like 8514, and try sending data on that port. If data is received, that means the problem still lies somewhere in the internal environment.
Another verification that can be done is to check if the binary is allowed to bind:
The below command can be used to verify this
getcap/opy/dynatrace/remotepluginmodule/agent/res/dsruntime/otc/dynatraceotelcollector
Example output
getcap/opy/dynatrace/remotepluginmodule/agent/res/dsruntime/otc/dynatraceotelcollector= cap_net_bind_service+ep
Its also possible that nftables can drop traffic silently, on systems using nftables, verify that traffic on port 514 is allowed, it can be tested using the command below
sudo nft list ruleset | grep 'dport 514'
Expected results
udp dport 514 accept​
or
tcp dport 514 accept​
What's next
Opening a support ticket -
Create a support ticket with all the steps mentioned above with the logs, also provide
 Syslog Ingestion Troubleshooting
Installation steps
Logs Troubleshooting Map
Version history
Last update:
‎20 Aug 2026 08:40 AM
Updated by:
