Troubleshooting
kanako_sato
Dynatrace Advisor
Dynatrace Advisor
Some applications require our JavaScript agent to run after other native XMLHttpRequest wrapping scripts have loaded (i.e. SAP Fiori). It is also possible a user is running certain Chrome extensions (i.e. LastPass, Requestly) which also wrap the native XHR prototype before our javaScript code is injected.
In such cases, our Basic XHR wrapper will be loaded afterwards, and will have to wrap these already "custom" wrapped XHR objects. This may lead to unexpected conflicts, as it is completely dependent on the previous wrapper's implementation, as opposed to the native API provided by the browser.
You have 2 possible solutions for this issue:
1. Go to Application -> Settings -> Injection -> Injection and define custom injection rule so that our JavaScript agent code should be injected earlier than other scripts.
2. If this is not an option, please go to Application -> Settings -> Capturing -> Async web requests and SPAs and enable Use Proxy API for XHRs. This option is available from Cluster version 1.238.
Version history
Last update:
‎28 Feb 2024 01:31 PM
Updated by:
Comments
ChadTurner
Legend
Great Write up @kanako_sato. I also have had issues with XHR enablement on apps, I appreciate these troubleshooting/tricks that we should leverage.
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
