Troubleshooting
alexander_dt
Dynatrace Helper
Dynatrace Helper
This is most likely caused by an error in context propagation on the code level.
Make sure the network libraries used in your application are covered by applicable instrumentation libraries and, especially if you instrument manually, that the context is properly injected into outbound requests, and extracted from inbound requests.
For details and samples on context propagation for the different supported languages, see Integration walk-throughs.
Version history
Last update:
‎01 Dec 2023 08:54 AM
Updated by:
Comments
kothapr
Participant
Hi @MaciejNeumann  and @alexander_dt
 I have posted a question on this https://one.dynatrace.com/hc/en-us/requests/264714?page=1.
I'm not using any network calls. I'm creating the spans with in the one method. But still Spans are not linked.
Prasanth
