One of the following may have occurred
- The process isn’t supported by our monitoring technology. You can always check which process types Dynatrace supports.
- The process isn’t working on your server. Make sure your servers are running and that the processes are operational.
- There is delay in communication between Dynatrace and your OneAgent. If this is the case, wait a few moments and try again.
- Your OneAgent isn’t working properly. Go to Settings > Monitoring overview to confirm that monitoring is enabled for the host running your software.
- Try installing OneAgent on a different machine.
