17 Jul 2026 10:16 PM - edited 18 Jul 2026 12:46 AM
This article applies to Dynatrace Operator based OneAgent deployments on Kubernetes and OpenShift (Cloud Native Full Stack / Classic Full Stack via CSI driver). It describes how to safely downgrade the OneAgent version pinned in a DynaKube, since the Operator and its CSI driver are designed around forward upgrades and do not natively support rolling back to an older OneAgent version in place.
Dynatrace Operator manages OneAgent version updates through the DynaKube custom resource. This model works well for upgrades, but the OneAgent is not designed for downgrades.
Customers typically run into this when:
DynaKube to point at an older image/version tag does not fully take effect, because a newer OneAgent binary/codemodule data may already be present in the CSI driver's per-node storage or installed on the node filesystem (/var/lib/dynatrace, /opt/dynatrace, CSI data volumes), and OneAgent pods will fail to start with "downgrade is unsupported" messages.If you are searching for this because you saw a OneAgent version mismatch across nodes after changing the pinned version in your DynaKube, or because a downgrade does not seem to apply, this article describes the supported procedure.
Before following the resolution below, confirm this applies to your situation:
kubectl get dynakube -n dynatrace -o yaml
DynaKube:kubectl get pods -n dynatrace -l app.kubernetes.io/name=dynatrace-oneagent -o wide
kubectl logs -n dynatrace ONEAGENTPODNAME20:40:33 Logging to /var/log/dynatrace/oneagent/installer/installation_2139424.log
20:40:33 Installation started, version 1.339.71.20260706-161947, build date: 06.07.2026, PID 2139424.
20:40:33 Detected platform: LINUX arch: X86_64
20:40:33 Error: Downgrading OneAgent is not supported, please uninstall the old version first 20:40:33 Error: Attempted downgrade from 1.341.53.20260716-085120 to 1.339.71.20260706-161947
Note: Downgrading causes a short monitoring gap while the DynaKube is removed and OneAgent is reinstalled. Perform this during a maintenance window where possible.
kubectl get dynakube -n dynatrace -o yaml > dynakube.yaml
kubectl delete -f dynakube.yaml
Because OneAgent and CSI driver data can remain on nodes depending on the monitoring mode, run the node cleanup script to remove leftover data before reinstalling an older version. See Update and uninstall Dynatrace Operator — Clean up nodes and the script itself: cleanup-node-fs.sh.
The script deploys a DaemonSet that runs a cleanup procedure on all Linux nodes in the cluster (amd64, arm64, ppc64le, s390x).
Before running the node cleanup, ensure that no DynaKube is deployed and all previously monitored Pods have been restarted.
# Download the script
curl -O https://raw.githubusercontent.com/Dynatrace/dynatrace-operator/refs/tags/v1.10.0/hack/cluster/cleanup-node-fs.sh
# Make it executable
chmod +x cleanup-node-fs.sh
# Run it (defaults to the "dynatrace" namespace; pass a namespace as an argument to override)
./cleanup-node-fs.sh
The script:
/var/lib/dynatrace, /opt/dynatrace, /var/log/dynatrace).Once all cleanup Pods complete successfully, the DaemonSet deletes itself automatically. If cleanup fails on any node, the DaemonSet remains in place for investigation — do not proceed to step 3 until this is resolved.
Edit the backed-up manifest and set spec.oneAgent.cloudNativeFullStack.image (and codeModulesImage, if applicable) to the known-good version:
apiVersion: dynatrace.com/v1beta6
kind: DynaKube
metadata:
namespace: dynatrace
spec:
activeGate:
capabilities:
- routing
- kubernetes-monitoring
- dynatrace-api
resources:
limits:
cpu: 1000m
memory: 6Gi
requests:
cpu: 200m
memory: 6Gi
apiUrl: <YOUR_API_URL>
metadataEnrichment:
enabled: true
oneAgent:
cloudNativeFullStack:
image: public.ecr.aws/dynatrace/dynatrace-oneagent:<PREVIOUS_VERSION>
codeModulesImage: public.ecr.aws/dynatrace/dynatrace-codemodules:<PREVIOUS_VERSION>
tolerations:
- effect: NoSchedule
key: node-role.kubernetes.io/master
operator: Exists
key: node-role.kubernetes.io/control-plane
operator: Exists
Replace <YOUR_API_URL> with the apiUrl from your backed-up dynakube.yaml, and <PREVIOUS_VERSION> with the specific OneAgent build you need (e.g. 1.339.71.20260706-161947). Adjust activeGate/metadataEnrichment settings to match your original configuration.
kubectl apply -f dynakube.yaml
Verify the rollout:
kubectl get pods -n dynatrace -w
Confirm all OneAgent Pods come up on the pinned version and report data to your Dynatrace environment as expected.
If this article did not resolve your issue, open a support ticket, mention that this article was used, and include:
kubectl exec -n dynatrace deployment/dynatrace-operator -- dynatrace-operator support-archive --stdout > operator-support-archive_$(date +%Y%m%d_%H%M).zip
Or if you don't use bash you can use the below:
kubectl exec -n dynatrace deployment/dynatrace-operator -- dynatrace-operator support-archive --stdout > operator-support-archive.zip
If you use OpenShift just replace kubectl with oc.
cleanup-node-fs.sh DaemonSet Pod did not complete successfully.If you find yourself needing to downgrade OneAgent versions repeatedly (e.g. to test compatibility before rolling out updates broadly), consider suggesting a Product Idea describing your use case.
More articles can be found on the Kubernetes/OpenShift troubleshooting map.
