18 Sep 2024
02:01 PM
19 Sep 2024
07:57 AM
Is it possible to configure an alerting when an ActiveGate goes offline?
Srikanth
19 Sep 2024 02:00 AM
Hey Srikanth,
You could alert on a self monitoring activegate metric such as dsfm:active_gate.jvm.cpu_usage. If you split by activegate and then alert on missing data then you'd be able to alert on them going down as when they're down the dsfm:active_gate metrics wont be reported. Would this be what you're looking for?
19 Sep 2024 10:08 AM
Thanks much @Fin_Ubels .
This helps to indirectly address the issue I'm trying to solve. I'd be more than happy if Dynatrace had OOTB solution that alerts when an activegate is offline.
19 Sep 2024 12:50 PM
I used this setup for one of our customer's env and it works like charm. (maybe you have to play a little bit with advanced model properties to fit your needs).
19 Sep 2024 02:01 PM
Hello @SrikanthSamraj
