10 Jul 2020 02:31 PM
Hi community, i have a question for you.
I have a Browser Monitor, which test an URL from the outside my company network. Now my Cluster ActiveGate, which execute this test, is automatic blocked by a firewall rule, so my browser monitor say "no data" in availability timeline, like this:
So, my question is, can i create an alert for no-data availability? Beacause, for now i must check this problem manualy.
Thank you for your help,
Regards
10 Jul 2020 02:55 PM
you should be able to configure outage alerts - I would assume that would include not data but I have not tested it. Check your settings - if is set to alert then we might need to look at another solution.
10 Jul 2020 03:09 PM
Thank you Chad for your answer. Unfortunately i have already set it, but this setting is related to a "unavailable" metric. My problem is "no metrics generated", so no test executed, and Dynatrace don't alert me.
10 Jul 2020 03:17 PM
hmm yeah this is going to be a tricky one Do you also have monitoring unavailable on the alert profile for this?
10 Jul 2020 03:46 PM
Yes Chad, i have this option enabled
10 Jul 2020 05:47 PM
Hmm, This might be a good RFE to post unless someone else has a solution to this
11 Jul 2020
10:01 AM
16 Oct 2023
03:24 PM
random_user
This is something we repeatedly asked for when migrating from the Classic synthetic. What is needed is an alert when the Activegate has lost contact with Dynatrace.
There is an RFE on this, it seems to be planned, but I would suggest you upvote it anyway:
