Custom alerts for CLS score.
cs6666
Visitor
Hi All, I have set up custom CLS alert using  metric selector option and static threshold value. I want to be alerted only after X hours if issue continue to persist, so I have added X hours of delay if problem remains open. Now the thing where I need more clarity is the Advance Model Properties option under Metric events.
Violating samples and sliding window in a min does not make lot of sense currently can we keep it blank .If yes then how alerting message will go. If not then what will be the appropriate value for violating sample and sliding window. I have default 3-5-5 at the moment.
Secondly how can I print the actual value based on which I am getting alerted.
0 REPLIES 0
