11 Feb 2024
02:30 PM
12 Feb 2024
07:57 AM
Hi Dynatrace Community,
I have created an SLO that triggers custom alerts
When the event occurs it generates a problem that I can query using API V2 with bellow details :
Is there a possibility that I can extract any of the key/values in problem details and display it in custom email body and send notification ?
In my situation I need to extract "key": "dt.davis.analysis_time_budget" and display it in email body.
The builting placeholders do not allow me to solve this situation.
Thank you in advance.
Best Regards
Farid
"data": { "eventId": "5613985181028457511_1707653400000", "startTime": 1707653400000, "endTime": 1707658440000, "eventType": "CUSTOM_ALERT", "title": "slo_dtd_inactivity", "entityId": { "entityId": { "id": "SERVICE_METHOD-E490FAD90B5A25FE", "type": "SERVICE_METHOD" }, "name": "migrate" }, "properties": [ { "key": "dt.davis.analysis_time_budget", "value": "0" }, { "key": "dt.davis.analysis_trigger_delay", "value": "3600" }, { "key": "dt.event.allow_davis_merge", "value": "false" }, { "key": "dt.event.allow_frequent_issue_detection", "value": "false" }, { "key": "dt.event.disable_davis_merge_reason", "value": "Set by event reporter" }, { "key": "dt.event.group_label", "value": "Custom alert" }, { "key": "dt.event.impact_level", "value": "Services" }, { "key": "dt.event.is_rootcause_relevant", "value": "true" }, { "key": "dt.event.metric_selector", "value": "(func:slo.slo_dtd_inactivity_migration_postpaid_prepaid):filter(eq(\"dt.entity.service_method\",SERVICE_METHOD-E490FAD90B5A25FE))" }, { "key": "dt.event.metric_threshold", "value": "8.0"
12 Feb 2024 09:44 AM
I would say Workflows is the answer for this specific scenario.
You can start with a problem trigger
https://docs.dynatrace.com/docs/shortlink/workflows-event-trigger#davis-problem-trigger
From here you can extract whatever information you need a use the new MS365 integration
https://docs.dynatrace.com/docs/shortlink/automation-workflows-microsoft365
15 Feb 2024 11:47 AM
Thank you PacoPorro for your answer, I will explore the scenarios you provided and keep you updated.
Best Regards
Farid
