Alerting
Process unavailable restarting
josean
Participant
Hi all.
we have a process that restarts automatically often, this restart can take up to 3 minutes.
Dynatrace is creating problems (Process unavailable) when it exceeds 1 minute.
How can I increase this time so that it generates a problem if it exceeds 3 minutes?
Thanks in advance.
BR, Jose A
Babar_Qayyum
Hello @josean
It is an availability-related alert. If you have more than one process in the process group then, you can also have a different type of control as well.
https://www.dynatrace.com/support/help/how-to-use-dynatrace/problem-detection-and-analysis/basic-con...
You can configure in the default alerting profile if you do not have an independent alerting profile.
Babar
This does works well when you are handling with Notifications, but not with Problem generation.
The problem will still being triggered but not notified to an external source.
I have created an idea for this: https://community.dynatrace.com/t5/Dynatrace-product-ideas/Pooling-interval-for-Static-Thresholds-on...
