Alerting
SSL Certificate Monitoring on a Managed Environment
emachuma
Frequent Guest
I have deployed a Certificate Validation Check (version 1.18) extension on a Managed Environment Linux ActiveGate. The endpoint  status is OK. Despite replicating the same configuration from a test environment, this doesn't trigger the certificate expiry metrics. What should I do to get a similar or better view/metrics?
ChadTurner
DynaMight Legend
DynaMight Legend
@emachuma were you able to get this resolved? I have had issues before where it was a permissions problem collecting the data, then traversing the network to supply the data.
-Chad
AgataWlodarczyk
Community Team
Community Team
@emachuma, have you already found a solution? If yes, feel free to share. Other Community members, like @ChadTurner would be happy to know the answer.
When passion meets people magic and innovation happen.
