17 Dec 2024
01:46 PM
18 Dec 2024
07:37 AM
Hi all,
Is there an option in Dynatrace to set a threshold for the minimum number of worker processes running in a process group instance? If the threshold is not met, can it trigger the creation of a problem ticket?
Prashanth Reddy
17 Dec 2024 04:25 PM
Yes, you can enable Process group availability monitoring and alerting
Best regards
17 Dec 2024 05:30 PM
Thanks for your reply. I have enabled it, but now I'm looking set a threshold for the minimum number of worker processes running in a process group instance.
18 Dec 2024 05:40 AM
You can use below metric for this. Use it in metric events for alerting.
builtin:tech.generic.processCount
