Automations
Keep Getting Promise { <Pending> } When Returning Current Version of Extension and Latest Version in Hub
badgerfifteen
Organizer
Hi all,
I'm currently working on a Code dashboard tile which shows the current version of an extension in relation to the latest version posted in the hub. I'm hoping to use this code for Workflows so I can be notified when extensions fall out of date. But I need to get over this first hurdle.
This is the code I have created so far:
async function checkVersion(extensionName) {
  // fetching extensions from the hub
  const response = await fetch(
    'https://{environmentid}.live.dynatrace.com/api/v2/hub/extensions2/' + extensionName,
      headers: {
        method: "GET",
        Accept: "application/json; charset=utf-8",
        'Authorization': 'Api-Token <REDACTED>'
  const result = await response.json();
  return result.extension2Details.recommendedCatalogVersion;
export default async function () {
  // fetching current extensions in environment
    'https://{environmentid}.live.dynatrace.com/api/v2/extensions',
      headers: {
        method: "GET",
        Accept: "application/json",
  const itemsArray = Object.values(result.extensions);
  const filteredItems = itemsArray.map(extension => ({
    'Extension Name': extension.extensionName,
    'Version': extension.version,
    'Version To Date': checkVersion(extension.extensionName).then()
  //console.log(checkVersion("com.dynatrace.filesystem").then());
  return filteredItems;
 I realise this may be an issue with items not being resolved yet as part of the checkVersion() function but even manually calling it makes this appear in the console:
Promise { <pending> }
..which I assume is happening in the table generated from this, too.
If I use await like this:
await checkVersion("com.dynatrace.filesystem")
…I do get some data back, but I can't use it in the mapping function as I get this:
"message": "Parse error: await isn't allowed in non-async function at file:///script.ts:34:30\n\n 'Version To Date': await checkVersion(extension.extensionName)
Evan1
Frequent Guest
Hi badgerfifteen,
As the error message indicates, you must be in an asynchronous function to use the "await" prefix. This prefix is ​​necessary to wait for the promise to resolve before proceeding to the next step. Currently, your function is asynchronous, but the mapping is not:
const filteredItems = itemsArray.map(extension => ({ // No async prefix here
    'Version To Date': checkVersion(extension.extensionName).then() // Need to be proceed before
You need to have something like that :
itemsArray.map(async (extension) => ({
To fix this, you can do :
      headers: {
        method: "GET",
      headers: {
        method: "GET",
  // Use Promise.all to handle asynchronous operations
  const filteredItems = await Promise.all(itemsArray.map(async (extension) => {
    const versionToDate = await checkVersion(extension.extensionName);
    return {
      'Version To Date': versionToDate
Let me know if it fix your problem
Have a nice day,
Sincerely
