Container platforms
Docker container embedded DT issues
davidjousma
Newcomer
Hi, new DT user and Mainframer here...We run zCX which is IBM Docker container extensions to run Linux containers in the traditional z/OS landscape.  Its a closed Linux environment with no root or sudo access.   We have DT running embedded in a couple of internally built containers and reporting on the dashboard.   The problem appears that DT is reporting the internal docker IP address of the container which is in public IP range of 172.*.    We have two sandbox zCX (docker) environments, with a container in each reporting.   The issue is that both containers are reporting on the same HOST IP address, so the monitoring stops even though the agent is up on both containers.  If I shutdown one of the containers then there is no problem.
I might be one of the few running DT in zCX, but this seems to be a docker issue more than anything else?  Anyone have any tips or hints?
Thanks, Dave
0 REPLIES 0
