22 Mar 2023
12:36 PM
23 Mar 2023
07:30 AM
Hi Everyone,
Hope you are doing well!!
We have a application which is configured in the application detection section using domain name of AKS Cluster. but no traffic/user activity is shown in the frontend section of Dynatrace. We don't know the issue what is causing it.
Please anyone can tell the possible issues. Thanks!:)
please find the below snippet
22 Mar 2023 01:55 PM
There may be a situation where the firewall cuts out this script. Another possibility is that you need to change the location of the script in the web file structure. Default is uploaded in the root of the page.
See the section in the documentation on troubleshooting for other verification options:
Let me know how you check if the script loads correctly.
Radek
23 Mar 2023 08:52 AM
Hi
Just to avoid any configuration issue, please check under My web application > Top 3 included domains > View full details, if you found there the Site, try to transfer it to your Application, and then review again the detection rules.
If there is nothing make sure your Timeframe is big enough ( Last 7 days? ).
This way you can at least be sure that this was not the problem.
Cheers
Marco
