12 Nov 2022 02:33 PM
I'm wondering if anyone can help me troubleshoot my Envoy monitoring setup. I've enabled Envoy monitoring and was expecting to see a bunch of Envoy proxies pop up in my 'Services' page including my ingress gateways but nothing is happening. The docs suggest that simply enabling envoy is all I need to do but it feels like I'm missing something here.
Any advice?
12 Nov 2022 05:22 PM
Hi stevemdt
First to all. you need to check 4 things. and could be usefull explain maybe with examples what you did.
1 - Envoy version ?
2 - do you enable envoy in technologies ?
2 - where are you trying to deploy the agent? (k8s, iks, eks, etc....)
3 - documentation that you follow up
this is the version that its supported - Envoy Support
here you can see where enable envoy - Get Started
maybe you are using this approach enabling istio in the yaml ? - DynaKube parameters
maybe you are using the prometeus approach - Monitor Prometheus metrics in kubernetes
it is hard to give advice without more information
hope it helps
have fun
