how to configure dynatrace to monitor hybris cronjobs, orders etc...
dhaval_p
Newcomer
Hello All,
I'm using managed dynatrace to monitor the hybris application and would like to configure dynatrace to monitor the hybris background processes(cronjobs), orders failures, etc...
Hybris version is: 1905
OneAgenet version is: Version 1.191.239.20200526-145639
Looking for any solutions or workaround, please let me know if any questions.
Thanks!
- Dhaval
6 REPLIES 6
DavorinKrivak
Helper
Hi Dhaval,
You can use the Hybris eCommerce fastpack (https://github.com/Dynatrace/Dynatrace-hybris-eCommerce-Fastpack/) to quickly setup custom metrics (JMX), request attributes and services specific to Hybris.
Note that this will use you custom metrics license (around 60 per host).
Best,
Davorin
Hi @Davorin K.
thanks for your reply.
I'd check this https://github.com/Dynatrace/Dynatrace-hybris-eCommerce-Fastpack, its archived repo. I'm looking for the practice if someone already using and without adding more stuff into infrastructure.
Thanks again!
- Dhaval
Markie_Duby
Dynatrace Enthusiast
Dhaval,
I don't know if you ever found a solution for this, but there are several training videos on the Dynatrace University which walk through Hybris Setup including setting up CronJob monitoring.
r_weber
DynaMight Champion
DynaMight Champion
Hi @Dhaval P., I'm the original author of the Hybris Fastpack for AppMon (almost 10 years ago) and I've worked in the last 3 years at SAP Hybris to bring this also to Dynatrace Managed as part of the SAP Commerce Cloud offering.
I've ported most of that to Dynatrace Managed, also CronJobs and BusinessProcessEngine and some more like order / Revenue Tracking. This is ongoing effort still, but if you need ore info let me know, I can share some insights.
Hi @Reinhard W.
thanks a lot for your response. 🙂
Yes, still I'm looking for the solution to configure hybris conjobs monitoring in dynatrace it would great help if you can share some insight which can help me to configure it.
Thanks!
Dhaval
r_weber
DynaMight Champion
DynaMight Champion
Hi Dhaval,
Happy to walk you through it and give you a few hints. I think the best would be a short interactive session. I have not made my work publicly available. You can contact me at r.weber(at)360performance.net and I will setup a meeting for us.
kr,
Reinhard
