DQL query for RPC ServiceEndpoint and ChannelEndPoint
bonelli
Visitor
Hi there,
I am using OneAgent SDK in Java to trace some RPC-like spans, and I want to find them later with DQL using a "fetch".
My snippet with the OneAgent SDK is this:
        OutgoingRemoteCallTracer tracer = OneAgentSdkSingleton.getInstance().traceOutgoingRemoteCall(
                method,
                "Foo",
                bar.getBar1(),
                ChannelType.OTHER,
                bar.getBar2());
and with a simple "fetch spans" I can find the spans just right, but I absolutely cannot find the value of getBar1() (ServiceEndpoint) and getBar2() (ChannelEndPoint) for the RPC call span.
Any idea on where can I find those values?
thanks
3 REPLIES 3
yanezza
Dynatrace Mentor
Dynatrace Mentor
Hi!
Have you tried to report and capture request attributes?
https://www.dynatrace.com/news/blog/capture-any-request-attributes-using-oneagent-sdk/
Yanez Diego Parolin
thank you @yanezza , yes we did work around it with a request attribute inside the scope of the tracer, and it works.
But it feels like a workaround, even if it is a nice one: why can't I get those precise fields out with DQL, since I can get everything else just fine?
yanezza
Dynatrace Mentor
Dynatrace Mentor
It should be due data protection reason. In this way you can mark the request attribute as sensitive data and only allowed users can view the value. Another example is if you don’t want to store the data in Dynatrace anymore, you don’t need to change the code and restart the application, with all complication.
Yanez Diego Parolin
