Dashboard Metric Explorer
DBAJames
Visitor
I can not longer add SQL metrics to my dashboard.  Despite giving me the metric or using one in user on another dashboard it says doesnt exist:
"errorType": "FIELD_DOES_NOT_EXIST",
"errorMessage": "The field `avg(sql-server.buffers.cacheHitRatio)` doesn't exist.",
6 REPLIES 6
AntonPineiro
Can you show a Data Explorer screenshot?
Best regards
what information do you require, just the list of SQL
Just one metric coming by extension. My point is if you are getting datapoints for some metric by extension.
Best regards
DBAJames
Visitor
Explore Metrics produces this (not working):
timeseries avg(`sql-server.general.userConnections`), by: { `dt.entity.sql:sql_server_instance` }
| fieldsAdd value.A = arrayAvg(`avg(sql-server.general.userConnections)`)
| limit 20
DBAJames
Visitor
SQL Server overview uses(working):
timeseries
connections = avg(`sql-server.general.userConnections`),
by: {`dt.entity.sql:sql_server_instance`}
| sort arrayAvg(connections) desc
| fieldsAdd entityName(`dt.entity.sql:sql_server_instance`)
| limit 20
sia_h
Dynatrace Champion
Dynatrace Champion
Please raise a support ticket. I’ve encountered similar issues and managed to find a workaround by accessing the classic data explorer, querying the metric, and then opening it in DQL.
