24 Dec 2024 11:13 AM
I have the following DQL
fetch dt.entity.cloud_application, from: -30m
| fields workload.name = entity.name, workload.labels = cloudApplicationLabels
| filter in(workload.name,array( $workload_name ))
| fields service = workload.name, version = workload.labels[`app.kubernetes.io/version`]$workload_name is a CSV variable
I want the query to list every to find every value in the $workload_name but it return only the first value in the CSV variable
24 Dec 2024 12:15 PM
This should work if you use the multi-select option:
| filter in(workload.name, $workload_name)
24 Dec 2024 12:23 PM
Thank you,
The solution works as intended. I did not want the variable to be displayed on the dashboard, it should remain a static variable. Additionally, I was unaware that the Multi-select option under display settings would impact the results.
