Dashboarding
Distribution graph and/or tables in Data explorer - eg Host Availability
holst
Guide
I want to show a table with Host Availability using the newer Host Availability metric with buckets for each state. A table for each host showing percentage of Up, no_data, shutdown_host etc
When using Splity By Host and availablity_state I just get multiple lines for each state. Plus I want to get the result in %, not number of measuring points per state
Anyone else fixed this?
PacoPorro
Dynatrace Guru
Dynatrace Guru
Are you looking for something like this?
Yes, but even better if there was a Percentage number for each.  I tried but failed so far with the calculation (in advanced mode)
This is quite good, my plan B
thanks
