09 Mar 2021
08:36 AM
09 Mar 2021
10:18 AM
Karolina_Linda
Hi there.
I would like to see how both the service flow and PurePath look in a cross environment.
I've searched in Dynatrace documentation, but I've only found two blog entries (an out-of-date entry from June 2019 and a very short entry from July 2020).
I need a full capabilities list:
Where can I get all this information? Can you provide pictures about how does it look and documentation?
We need to know all these in order to design the architecture of tenants (if it is better to split tenants by entity or by region, etc). We have hundreds of projects that interact between them, and an entire view it is key. But they belong to different owners/entities, although the operators are the same.
Thanks a lot.
09 Mar 2021 08:58 AM
unfortunately, the interconnection of two environments does look like as described in the blog posts. Thus you won't get:
I don't believe this will change anytime soon. What you can get:
Things to keep in mind:
09 Mar 2021 07:48 PM
When systems interact with each other it is typically better to have fewer tenants, not more. Would management zones within the same tenant accomplish what you are trying to do? You can limit access to the data/settings/etc but still track calls from one application/system to another.
10 Mar 2021 10:17 AM
Thank you both, @john_leight and @Julius_Loman for your answers.
I'm going to propose an RFE to improve this capability. I understand that in a service flow only can get data from the current tenant.
But I think that it would be great to provide an entire overview of the entire service flow. Maybe a dependency map with only response times and errors. Then, if you want to get specific information, by clicking go to the specific tenant (like currently).
Regards, have you a nice day!
