How to create CPU usage dashboard
suraj_gupta945
Participant
How to create CPU usage dashboard using aggregation "MAX" in dynatrace SAAS/Managed...
ChadTurner
This can be done by creating a custom chart. Select "Create custom chart" on the left hand side, Type in CPU and select the option as desired, then once the chart comes up, select the aggregation of Maximum. From there you should be all set, dont forget to pin it to the desired dashboard!
-Chad
