Dashboarding
Reorder column when DQL quering
I noticed that when in DQL we do: | fieldKeep x,y,z,u in DQL
We cannot choose the order of the column to be displayed in table. Can you order the column without Dynatrace ordering it automatically?
Eric_Yu
Dynatrace Mentor
Dynatrace Mentor
If you want to reorder while keeping specified columns, I'd recommend using the fields command instead.
