20 Jul 2020 09:36 AM
Every time I change the underlying query or even the title of a USQL-based dashboard tile, its position and size reset. Is there any way to prevent this?
21 Jul 2020 05:01 PM
I'm not sure what's causing this or of a fix at the moment, but it is something that is being looked at internally.
Best regards,
Justin Hogue
23 Jul 2020 11:08 AM
Thanks for the feedback! This has been looked at and fixed in the meantime.
23 Jul 2020 12:04 PM
Hi Roman, thanks for the response. Unfortunately, it does not seem to be fixed, behaviour is still the same after updating the USQL. I even created a new dashboard to make sure, but there the same thing happens.
27 Jul 2020 10:36 AM
Which version are you on? The fix should come with version 1.198.
17 Aug 2020 09:49 AM
Hi Roman, we've updated to 1.198 and now the issue doesn't occur anymore. Thanks!
