31 Jan 2024 05:59 PM
How can i make the words on dashboard bigger than the max default config "Large" on dashboard? i want to se the letters from metrics bigger, something in the querys could be good.
31 Jan 2024 06:27 PM
There isn't a way to do it directly on the data tile.
However, if you're looking to put headers, identify tiles and organize your dashboard you can use markdown tiles for this.
https://docs.dynatrace.com/docs/shortlink/available-tiles#markdown
31 Jan 2024 06:51 PM - edited 31 Jan 2024 06:54 PM
You can do whatever you want with image tile. I usually use this workoround.
real dashboard - transparent background - png
Alex Romanenkov
