can we pin process group screen to dashboard?
Anonymous3
Participant
I wanted to include the process group level metrics to the dashboard - is there a way it is feasible? By default, the screen doesn't offer "pin to dashboard" option Please advise
3 REPLIES 3
Mizső
DynaMight Leader
DynaMight Leader
Hi @Anonymous3,
If I am not worng it is not possible. Maybe the community members will correct me.
PG level metrics numbers are limited. (you can check it in your env. at metrics by the dimension filter)
Most of the metrics can be splitted and can be vizualized by process group instances (individual member of a PG).
I hope it helps.
Best regards,
Mizső
Certified Dynatrace Associate
Anonymous3
Participant
Thanks Mizso. this helps.
Julius_Loman
There was never a dashboard tile for a process group as the important metrics differ between technologies. With Data Explorer you can create your own tile and display the metrics you consider important.
