16 Nov 2017
01:00 PM
11 Jan 2022
12:45 PM
AgataWlodarczyk
Hello All,
Is that possible to show maximum value of specific measure as point in dashboard? You can see the sample picture in attachment below.If it is done, it will be perfect to serve details at the same dashboard.
23 Nov 2017 03:14 PM
Hi Murat,
Yes, you can for several metrics in Dynatrace. Edit the chart in which you wish to show the maximum value, and change the aggregation for the metric:
HTH,
Hayden
