29 Feb 2024
09:21 AM
01 Mar 2024
07:13 AM
I am trying to get PID for a running process from Dynatrace. I am using Environment API and giving "PROCESS_GROUP_INSTANCE" as entity type.
This API do not sends PID for the process. Can some one help in finding a correct REST endpoint which will return PID for a running process.
29 Feb 2024 09:41 AM - edited 29 Feb 2024 09:44 AM
I think that is not reachable via API, but not sure 100%.
You can see PID from Process instance snapshots.
Best regards
01 Mar 2024 07:17 AM
Can you please suggest how I can pull this data from process instance snapshots which contains PID, PPID command line etc for all the processes.
01 Mar 2024 07:40 AM
I do not see an out-the-box solution if you want that information outside Dynatrace.
Maybe re-searching if those metrics are available in Grail. Are you in a SaaS Grail enabled tenant?
Best regards
04 Mar 2024 07:34 AM
Yes We do have Grail enabled tenant but we also want to support a non-grail tenant. We support log monitoring for both of the tenants type.
Regards
04 Mar 2024 07:39 AM
I do not see a way to get it from Managed. I someone does not provide you an answer, you can raise a product idea.
Best regards
05 Mar 2024 07:51 AM
Product idea in relation to this -> https://community.dynatrace.com/t5/Product-ideas/Provide-an-api-to-pull-the-process-details-such-as-...
