POWER BI - Totalcount over 500
Sullivan
Observer
Hi everyone,
I would like to know if anyone has used Power BI to export problem data from API V2.
API V2-> Problems -> List of problems observed in the specified period.
I am experiencing a problem I have +500 problems, how do I get more than 500 rows in PowerBi?
Request :
https://mytenant/api/v2/problems?pageSize=500&from=now-30d&problemSelector=status%28closed%29
3 REPLIES 3
AntonPineiro
I do not use Power Bi but you need to iterate against "nextPageKey" in body answer:
We need to make a loop until that is null, it means, you need to call problems API more than one time, in chunks of maximum 500.
Best regards
Yosi_Neuman
Hi @Sullivan,
Please check @vasile_gafton  answer for your question.
HTH
Yos
Sullivan
Observer
Hi everyone,
Thank you very much for your answers, I've managed to do it in PowerBi.
