31 Jul 2023 08:55 AM
I've been looking into what automation capability is available for Dynatrace Managed Customers.
Cloud Automation doesn't strictly specify whether it's supported by Managed or not and looks to require a Dynatrace hosted instance - Cloud Automation requirements | Dynatrace Docs
Additionally, since AutomationEngine/Workflows is only a Saas product, are there any direct webhook/integration automation capabilities available for on-prem Dynatrace Managed solutions?
07 Aug 2023 08:33 AM
@Jarrod_Brammer Cloud Automation, AutomationEngine, and Workflows are available only in the SaaS deployment model. There are no plans currently to make them available on-premises with Dynatrace Managed. The reason is that they rely on Grail which is available only in Dynatrace and was architected that way, which is unsuitable for on-premises deployments.
What you can use is alternatively is:
