24 May 2026
06:29 PM
25 May 2026
01:27 PM
Hello Dynatrace Community,
I am currently reviewing the Dynatrace Classic licensing documentation for Dynatrace Managed to do some capacity planning.
According to the official documentation, an HTTP monitor consumes 0.1 DEM units per synthetic request.
My question is: Does this 0.1 DEM rate apply equally whether the HTTP monitor is executed from a Public Location or a Private Location (on-premises ActiveGate)? Or is there a differentiation in the consumption?
I would appreciate it if you could clarify how Dynatrace Managed handles this currently.
Thank you.
Aboud
25 May 2026 07:35 AM
I am not aware of any difference.
Best regards
25 May 2026 11:50 AM
Hi @Aboud1
The Dynatrace documentation explicitly states: "It doesn't matter if the monitoring location is public or private" when calculating HTTP Monitor DEM consumption
https://docs.dynatrace.com/docs/license/digital-experience-monitoring/http-monitor
For DEM unit billing purposes, the consumption rate is identical regardless of location type.
Sujit
