Minimum Resource Requirements for Dynatrace Managed POC with 10 HU
agylpradipta
Helper
Hello everyone,
I would like to ask about the system requirements for Dynatrace Managed.
Refer to the following documentation: https://docs.dynatrace.com/managed/managed-cluster/installation/dynatrace-managed-hardware-and-syste...
It states that for a Micro (max 50 HU) setup, the required resources are:
  • 4 vCPU
  • 32GB RAM
  • At least 200GB storage
Currently, I want to do a POC for a prospect, who based on our calculations, will only consume 10 HU.
Since the POC will be conducted in their Dev/QA environment first.
Is it possible to reduce the resource requirements I mentioned above?
If so, what would be the minimum requirements?
Thank you.
0 REPLIES 0
